Photoshop freezes while scaling
COW Forums : Adobe Photoshop
Weston Selleck
on May 16, 2012 at 10:44:57 pm
I just had some disk corruption or file corruption or something like that errors due to something. I'm not exactly sure what happened, but I was rendering a huge video and after and possibly during the render I noticed that whenever I scaled an object in Photoshop, it would freeze. The only way to get out of the freeze would be to A) End the Process and then hit 'cancel' or B) Minimize and unminimize Photoshop. I ran chkdsk and my file structure corruption problem ended, but Photoshop still froze whenever I scaled. I'm running CS5 and have tried unenabling OpenGL and messing around with bunch of options to no avail. I did unplug my external drive and it worked for a few seconds but then started to freeze again. Everything else in Photoshop works like normal, it's just whenever I scale objects, and specifically whenever I hit the check mark.
Weston Selleck
Re: Photoshop freezes while scaling
on May 16, 2012 at 10:58:20 pm
Also if it helps, I was playing Diablo III at fairly high graphics just prior, and my specs are as follows:
Dell XPS 15
i7
8GB Ram
