Photoshop cs5 extended is exporting video as interlaced upper odd regardless of interlace box being checked or unchecked.
COW Forums : Adobe Photoshop
Rich Beer
on Jan 23, 2012 at 12:03:52 am
I have been using AE cs5 for color-grading and realized that it was interlacing my progressive video even though the interlace box was unselected. After some online research I found out that someone else had figured out that if they selected then unselected the interlace box then it would output progressive as it should. Is there a similar issue with Photoshop cs5? Now I am using Photoshop for some color-grading and when I export the footage it outputs to interlaced (upper odd) no matter what I do. Does anyone know if there is a way to trouble shoot this? Is there any resolution degradation if I expand my workflow to include taking interlaced footage from Photoshop to After Effects to take it back to progressive?
Rich
Apple MacBook Pro
OSX 10.6.8
Photoshop CS5.1
Scott Roberts
Re: Photoshop cs5 extended is exporting video as interlaced upper odd regardless of interlace box being checked or unchecked.
on Jan 23, 2012 at 2:00:13 am
Is your source footage interlaced?
LittleBlackBird.net
My Blog
Rich Beer
on Jan 23, 2012 at 9:28:08 am
No the source footage is prores 4444 field none progressive rendered from FCP 7. Is that redundant? If there are no fields then it must be progressive right?
