Composite PNG files into layered PSD Sequence
COW Forums : Adobe Photoshop
Richard Diffend
on Jan 9, 2012 at 10:25:35 pm
I have 5 directories of files exported from Flash representing a layer. Each file is a PNG. Each directory has the same number of files representing each frame that was in the flash file (about 1500 frames).
What I'd now like is a way to batch composite each file per frame, into a PSD file with layers intact. Basically have the script grab the " *filename_001 " from each directory and composite them in order, into a layered PSD file, then save that file to a new directory. Repeat for all 1500 files.
Does anyone know of a simple way to do this?
