RGB TO CMYK problem
COW Forums : Adobe Photoshop
Ricky Milling
RGB TO CMYK problem
on Dec 13, 2011 at 6:22:53 pm
Rite i have a problem. I am being given eps files that have a transparent background, theand they need to be put in to Final Cut Pro. I know that CMYK doesnt work in FCP so that they have to be in the RGB spectrum, however when i convert them, their values change and as they are clients specific logos i cannot change them. Is there ay way for me to match the CMYK colours in RGB or any way around this problem.
Ricky
Scott Roberts
Re: RGB TO CMYK problem
on Dec 14, 2011 at 11:26:23 pm
They are two different color spaces with colors that overlap and a lot that don't. So getting them to match exactly is impossible. You can get them close, but the reality is there's colors that each have that the other doesn't. Sometimes converting to LAB first then to RGB helps.
http://en.wikipedia.org/wiki/Color_space
LittleBlackBird.net
GraphicsDump.com
