photoshop cs5 problem with video layers and KEYFRAMES
COW Forums : Adobe Photoshop
Esther Casas
on Oct 18, 2011 at 4:52:28 pm
Dear all!
I am using photoshop cs5 (opened at 32bit mode as for video layers) to "paint" frames from a quick time movie I have exported with after effects (I used quick time format and i am exporting RGB and alpha channels).
I have done this before and it worked with Photoshop cs4, but not anymore(?) and I have teh same problem with cs5. The problem is:
I tried importing in two different ways:
1) import video frames to layers, then i can work in timeline frame to frame as you do in after effects.
2) open: I open a quicktime, and it shows you the video layer for it.
the problem: the timeline shows my frames, but when you go through all of them is only showing you one single frame!!!???
Thanks in advance!
Esther.
