Alpha Channel to Transparency
COW Forums : Adobe Photoshop
Chris Orchard
on Aug 27, 2011 at 5:32:45 pm
Am at a loss and I know there must be a simple answer but...
Working on a 32bit PSD with a complicated alpha channel
When I apply my changes in Photoshop using the clone stamp or whatever, the alpha channel isn't affected, only the RGB channels, so it looks great in Photoshop but when saved and re-imported into After Effects or the like, the old alpha channel in place renders all the new work I did transparent.
Can I take the original image before I start editing, and apply the alpha channel onto a copy of the background as a layer so I can See the transparent checker pattern and not have to worry about an independent alpha channel? This way edits to the image will automatically include the transparent data?
Keeping in mind this is a 32bit image, so many tools in Photoshop CS5 64 bit will not work.
Orchard Film Studios, Canada
Scott Roberts
Re: Alpha Channel to Transparency
on Aug 28, 2011 at 3:52:52 am
Take a look at the channels in photoshop. what do you see?
LittleBlackBird.net
GraphicsDump.com
Chris Orchard
on Aug 28, 2011 at 4:10:42 am
Hi Scott, I see the RGB channels of what I want to see and the alpha of the original ...per the graphic. Am I misunderstanding your question?
Cheers,
Chris
