Paths with Magic Wand tool?
COW Forums : Adobe Photoshop
Kyle Sowden
on Aug 7, 2011 at 12:09:42 am
So i'm trying to make a 3d image from a 3d image using C4D, and to do that I need to export the work path from Photoshop.
To get the best look, I want to use the magic pen tool. But how do I save the path that the magic wand tool creates? The Pen tool saves it to the 'paths window' automatically?
Scott Roberts
Re: Paths with Magic Wand tool?
on Aug 8, 2011 at 11:12:51 pm
In the Path Palette flyout menu - select "Make Work Path" then set your path tolerance (i usually set it to .5)
LittleBlackBird.net
GraphicsDump.com
Weston Selleck
on Aug 17, 2011 at 7:26:05 am
After making your selection, go into the paths panel and on the bottom there is a button, I can't remember exactly what it looks like, but when you hover over it it should say something like "Make Work Path" just click that.
-Weston
