How to create this block letter effect?
COW Forums : Adobe Photoshop
Devon Lee
on Jun 27, 2011 at 12:20:50 am
I need to know how to do this effect in Photoshop/Illustrator. Thanks for any help.
Scott Valentine
Re: How to create this block letter effect?
on Jul 2, 2011 at 7:13:43 pm
What version of PS do you have? In CS5 Extended, you'd do this with the Repoussé tool and simply extrude the text, using a scaling effect along with a short lens to get the appearance of depth.
I haven't done this in AI in long enough that I couldn't tell you right off the bat.
Jaime Montaño
on Jul 5, 2011 at 6:02:02 pm
I hope to be clear enough.
- Create your text layer and duplicate it. Work in hires.
- Decrease size and align both to center.
- Reduce opacity of both at 50% so you can see behind.
- Using the pen tool conect the dots between both and create shapes.
- Add a bit of shading via soft brush and there you have it.
I've done this in 5 minutes.
