See through Text? Expert advice?
COW Forums : Adobe Photoshop
Lincoln Waldron
on Mar 18, 2011 at 6:36:32 pm
Hi
I have imported a solid and a border from Adobe illustrator and want the text to go be see through, sort of like an Alpha channel.
How could I do this both in Illustrator and Photoshop?
See the image below- Thanks
L
David Cabestany
Re: See through Text? Expert advice?
on Apr 2, 2011 at 1:07:10 am
make the object white with the parts you want to be transparent black, then change its blending mode to screen, if you do it inverted (black/white) then choose multiply instead.
