Brush to Path
COW Forums : Adobe Photoshop
Ralph Johnson
Brush to Path
on Jan 25, 2011 at 2:24:35 am
Is there a procedure for converting a Photoshop brush to a path so that I can then animate it with a stroke in After Effects. Thanks very much.
David Cabestany
Re: Brush to Path
on Feb 5, 2011 at 6:57:15 am
Paint a simple instance of the path, as big as you can, do this by clicking once. Then command click on its layer thumb to select its transparency, then go to the paths palette and from the side menu select create path, try different values for the tolerance and finally finesse the path on illustrator.
This will only work with hard edged brushes, tough.
