Cannot paste a path from illustrator
COW Forums : Adobe Photoshop
Erik Waluska
on Dec 7, 2010 at 5:23:59 pm
For some reason, I'm no longer able to paste a path from Illustrator to Photoshop. It works fine on my Mac at work and I'm fairly sure it was working fine on my PC at home but now when I copy a path in Illustrator and try to paste into Photoshop nothing happens, no dialog appears and the Edit>Paste option is grayed out. I tried it in a new document and with different paths and also tried pasting into After Effects, which worked fine, but not Photoshop. I couldn't find any preference options for this either. Does anyone have any idea what could be causing this?
-E
Erik Waluska
Re: Cannot paste a path from illustrator
on Dec 7, 2010 at 5:59:31 pm
Never mind, it's working now. After Effects just locked up for no reason and I had to force quit so I closed all open Adobe apps and restarted them and now the copy/paste path is working. There were several Adobe updates including a couple for photoshop that I ran when I first turned on the system today so I don't know if that had anything to do with it or not.
