Brush that draws parallel, directional lines.
COW Forums : Adobe Photoshop
Daniel Jay
on Dec 7, 2010 at 1:19:25 am
I'm trying to figure out how to make a photoshop brush that draws parallel lines that follow the direction of the stroke. I created a brush stamp with a line of dots. It works fine when there's no angle control (under shape dynamics). However, when I set the angle jitter control to direction, which is what I want, the stroke breaks up into little dots. Any ideas on how this can be done? Thanks.
In this example, Angle control: off is what I DON'T want.
Angle control: direction is what I DO want, except as solid lines.
David Cabestany
Re: Brush that draws parallel, directional lines.
on Dec 13, 2010 at 5:14:50 am
On brush tip shape, change the spacing to 0%.
