adjustments
COW Forums : Adobe Photoshop
Charles Williams
adjustments
on Oct 4, 2010 at 5:11:52 am
Im touching up a photo i took. ive been using the select tool and creating vector mask to adjust on a different layer. now i applied some adjustments to some building and realized that i missed one of the buildings. so i applied a new mask on this building and i want to apply the exact same adjustments from the first vector mask to this one...HOW DO I DO THIS?!?!?!
Thank you :-)
Mike Gondek
Re: adjustments
on Oct 19, 2010 at 4:32:26 am
I am struggling with your post to understand if you actually have a vector mask(with bezier handles and vector points), or if it may be a bitmapped mask(black and white pixels and possibly some gray.
If you have a vector mask, copy this, then go to the other layer mask, and paste it.
If you have a bitmapped mask, command click to make a selection of marching ants,then go to the layer you want to add the building, and fill the marching ants with white.
