Creating MOV files with alpha in PS for lower thirds for AVID
COW Forums : Adobe Photoshop
meg freeburn
on Jul 7, 2010 at 5:09:51 pm
I am currently using PS Extended CS4. I am having difficulty exporting a .MOV file with alpha for AVID Media Composer. I am currently trying to export using the setting that I use when creating After Effects lower thirds which is:
MOV
AVID DNxHD Codec
Millions colors+
1080i/59.94 145 8-bit
color levels: RGB and 709 (I tried both)
All frames
alpha channel straight-unmatted
I have also tried to export with a separate alpha channel in my psd file visible where white on my alpha layer is intended to be opaque, and black is not visible.
Also working using a 32bit system.
Suggestions would make me happy, thanks!
Scott Roberts
Re: Creating MOV files with alpha in PS for lower thirds for AVID
on Aug 20, 2010 at 8:05:40 am
The thread here might help you: http://community.avid.com/forums/p/72403/405047.aspx
http://www.youtube.com/graphicsdump
http://www.myr3d.com
