How to get rid of background cracks
COW Forums : Adobe Photoshop
Russell Levenson
on Jun 14, 2010 at 7:50:19 pm
Okay so I'm dealing with a picture of a tree. The whole background is white and I need to get rid of the thousands of little white background areas in between the leaves. Is there a way to sample the value white and then delete the rest of the white in the picture? Thanks.
Paul Benson
Re: How to get rid of background cracks
on Jun 17, 2010 at 1:41:28 am
Magic wand with the non-contiguous option is the poor man's choice.
Select Color Range is likely what you want. Plenty of tuts on the net about it.
Pauley
Jochem Baron
on Jun 17, 2010 at 6:41:37 am
You could also use the background eraser tool. Search for a tutorial on google.
Christina Rodriguez
on Jun 18, 2010 at 11:46:54 pm
May I suggest that you work in a mask... I find it to be much more flexible incase you make a mistake...
Plus, lets say you remove the edges BUT they are too hard... If you Don't have a mask it will be hard to blur the edges but not the actual image. With a mask, you don't need to worry about blurring the image, only the mask. It is non destructive.
And to make it permanent, you can just drag it to the trash and select "Apply Mask"
C.R.
