Export layers from photoshop with scripts - no serial numbers
COW Forums : Adobe Photoshop
Brian Wagner
on Feb 22, 2010 at 6:51:55 pm
When I export layers in photoshop using the "export layers to files" script it includes a serial number. Is there a way to use this script without adding the serial numbers?
Mike Gondek
Re: Export layers from photoshop with scripts - no serial numbers
on Feb 23, 2010 at 7:10:52 pm
good question, I remember running into this before.
Try imageready, I believe there was an option to use layer names.
If it does not let us know how you would want the files to be named,a s that might help locate a solution.
Either that or I downloaded on utility on the pc for file renaming that had more features than batch rename in bridge.
Brian Wagner
on Feb 23, 2010 at 8:07:21 pm
Thanks for responding. I work on CS3 and CS4, imageready is discontinued on those suites.
If I export the layers from photoshop I get a serial number as the prefix, I saw that I could rename in bridge but it doesn't take off the serial number prefix.
Any other thoughts? Thanks.
Brian Wagner
on Feb 23, 2010 at 8:09:06 pm
