PS action to combine all open images into one comp
COW Forums : Adobe Photoshop
David Taylor
on Feb 18, 2010 at 4:33:32 pm
Seems like this should be an automated feature or something. But I'd like to quickly combine all the open single layer images into one multi-layered comp. Is there such a action? I've googled but to no avail, probably not wording it right.
Paul Benson
Re: PS action to combine all open images into one comp
on Feb 21, 2010 at 12:58:26 am
I think you need a script instead of an action. Googling 'photoshop script combine images' led me to this site:
http://www.russellbrown.com/scripts.html
The Merge-a-matic script may be what you are looking for.
Pauley
Mike Gondek
on Feb 22, 2010 at 6:33:00 pm
There already is in CS4 (might exist in earlier versions)
files> Scripts>>Load files into stack
then just follow the prompts
David Taylor
on Feb 23, 2010 at 8:05:15 pm
That's the one! I knew I'd used it before, just couldn't remember the right phrase, STACK!
DT Motion Pictures
http://www.davetaylormp.com
Scott Roberts
on Feb 23, 2010 at 4:31:52 am
Another way to do this is to drag the open files into one file, and by holding shift (if the documents have the same dimensions), it will stack centered.
http://www.youtube.com/graphicsdump
http://www.myr3d.com
Lana Purnell
on Apr 14, 2014 at 5:23:50 pm
There are a few options I know of, none are perfect.
One: File>Automate>Contact Sheet II
This will preserve layers, include captions of the file titles, but they're really really small (it's a contact sheet, after all)
Two: File>Automate>Picture Package
This will not preserve layers and is not included in versions beyond CS5. However, if you take the time, you can adjust the layouts in one go, however you wish. You can find the plugin here: http://www.adobe.com/support/downloads/thankyou.jsp?ftpID=4688&fileID=4376 and how to install it here: http://projectwoman.com/2012/10/install-picture-package-in-photoshop-cs6-st...
Three: File>Scripts>Load Files into Stack
Preserves layers but will require rearranging.
Hope this helps.
