CMYK in Camera Raw
COW Forums : Adobe Photoshop
Jim Arco
CMYK in Camera Raw
on Jan 26, 2010 at 10:25:30 pm
Is there a way to work with CMYK using camera raw files?
John Mensinger
Re: CMYK in Camera Raw
on Jan 27, 2010 at 9:21:43 pm
In a sense, that would defeat the purpose of Camera Raw, where the idea is to make global adjustments in the largest available color space.
Perhaps if you frame the question in a more specific context with regard to what you're attempting to accomplish, there may be other angles.
John M:
All of the vim with none of that annoying vigor.
Jim Arco
on Jan 29, 2010 at 4:03:49 am
To answer your question: I have a workflow I use to get good skin tones (from Mark Dubovoy) and I would also like to be able to use it with RAW files.
"...that would defeat the purpose of Camera Raw..." You make a good point, however. I guess I'll need to convert from RAW to something else before I do final color correction.
