Removing objects frame by frame in videos with Photoshop
COW Forums : Adobe Photoshop
Tim Drexler
on Nov 7, 2009 at 1:24:21 pm
Hi. I have an IMac, Photoshop Elements, and Final Cut Express. Can I use Elements to remove objects, frame by frame, from videos that I make in Final Cut? If so, is it the easiest most efficient way to do this? If not can you recommend software to do this? Thanks.
Theo van Laar
Re: Removing objects frame by frame in videos with Photoshop
on Nov 10, 2009 at 5:54:27 pm
Sorry, but only the extended versions of Photoshop CS3 and 4 can work with video.
To do what you want to do, Adobes AE is more suitable.
Theo
