RAM and crashing problems with large Batch or "Render Video"
COW Forums : Adobe Photoshop
Lu Nelson
on Oct 29, 2009 at 12:28:41 pm
Hi all,
does anyone know what kind of setting I might be missing?
I'm trying to process video clips in Photoshop (I have a particular filter that only exists for PS, not AE), and all types of "Render Video" export I choose result in crashes after a few hundred frames. I've now resorted to pre-rendering the clips as image sequences out of AE and having PS do a Batch Process on them (which is twice as slow, but I though perhaps less prone to crashing), but there too, it stops after maybe 500 frames saying it's out of RAM.
What gives? I'm using CS4 10.0.1 on a MacPro with 8GB of RAM
LMN
Lu Nelson
Berlin, Germany
[MacProQ2.66, 8GB, Sys10.5.6, FCP 6.0.5, AE 9.0.2]
Lu Nelson
Re: RAM and crashing problems with large Batch or "Render Video"
on Oct 30, 2009 at 3:18:27 pm
Seem to have solved my problem...
held down option command shift at startup of PS and checked "Yes" to erase the settings file
Also updated the plugin I was using; one or the other seems to have worked
LMN
Lu Nelson
Berlin, Germany
Theo van Laar
on Nov 1, 2009 at 6:22:38 pm
Good to read that you solved the problem!
Theo
