merge two text overlay layers without losing effect?
COW Forums : Adobe Photoshop
Nick Dantonio
on Sep 11, 2009 at 9:08:36 pm
I'm using PS CS4 and I have two text layers on top of each other (they same the same thing) and the layer style for both is set for "overlay". I want to merge (and rasterize) the two layers but keep the look of the doubled up overlay effect.
Can this be done??
Thanks...
Matt Sepeta
Re: merge two text overlay layers without losing effect?
on Sep 14, 2009 at 4:01:26 pm
I use a work-around method to accomplish this. I know that merging layers makes effects go all wonky so I figured out this method...
I make a new empty layer, then make all other layers, except for the empty layer and the layer you wish to be rasterized invisible. Then I do "merge all visible". Then repeat. You lose the ability to change the effects, but it might work for what you are trying to do.
Good Day
Richard Harrington
on Sep 14, 2009 at 4:50:18 pm
Make a new layer first and hold down Option or Alt when merging to merge a copy to the selected layer
Richard M. Harrington, PMP
Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
jim cascarina
on Sep 15, 2009 at 9:07:12 am
quick and dirty = put new layer under the text layer and command E
