Cutting up contact sheets or tiled image?
COW Forums : Adobe Photoshop
Dustin Nelson
on Sep 3, 2009 at 5:47:05 pm
Is there a way to save basically reverse a contact sheet? Or to cut up an image into several images of a specified size?
I have to do this for several files, so if there is an easy way to do it, it would save me a lot of time... Thanks in advance!
Theo van Laar
Re: Cutting up contact sheets or tiled image?
on Sep 4, 2009 at 4:35:16 pm
FILE-AUTOMATE-CONTACTSHEET II
Good Luck!
Theo
Dustin Nelson
on Sep 4, 2009 at 4:52:34 pm
Yeah, I know how to make a contact sheet, but what I want to do is take an existing contact sheet and cut it up. So that each image in a square of the contact sheet becomes a separate document.
So as an example, having a contact sheet with 6x6 tiled images, and then being able to take that, and end up with 36 individual files, one for each tile.
Unless I am missing something, you can only build contact sheets from Contact Sheet II, not break them down into their individual components.
