instances or reference objects
COW Forums : Adobe Photoshop
Michael Goldberg
on Jul 19, 2009 at 2:44:28 pm
Is there a way to use an "instance" or "ref" object in Photoshop (i have CS4). I have a bunch of panels across a wall. I probably have about 30 objects. I'm using groups and copying and moving the groups. What I'd like to do is have 1 master object, and uses instances. That way if I decide to make a change to the master object all of the copies will follow. Right now if I make a change, I need to go in and change each object?/
Mike
