Batch Process tiffs to jpg
COW Forums : Adobe Photoshop
Thad Ciechanowski
on Jun 25, 2009 at 12:55:48 pm
I'm trying to batch process about 1500 16 bit tiffs to 8 bit jpgs. I record a new action: open the file, convert the bit mode to 8, save as a jpg in a different folder and then close.
However, when I run the batch it saves the first image as a jpg and the rest as 16bit tiffs, basically just creating a copy in the new folder. I tried using PS 7 and PS CS3, on both a Mac and PC. Same thing always happens.
I'm not sure what I could be doing wrong... any ideas?
Thad
Thad Ciechanowski
Re: Batch Process tiffs to jpg
on Jun 26, 2009 at 12:57:10 pm
Just in case anyone's interested or encounters this issue, here's how I did a work around. You'll need After Effects:
I imported my 16 bit tiffs into AE as a clip sequence and then exported the sequence as an 8 bit JPG sequence. Tada!
http://www.dijitmedia.com
Richard Harrington
on Jun 26, 2009 at 4:53:12 pm
File > Script > Image Processor
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Thad Ciechanowski
on Jun 26, 2009 at 6:41:08 pm
I primarily use PS 7.0 which I believe doesn't have that feature. The CS2 version I have is on my Mac (Powerbook G4) which is considerably slower than my current PC configuration. I'll keep that in my back pocket for next time though.
Thanks again.
Thad
