creating Letterbox Mattes in Photoshop for FCP HD Layoff - HELP!
COW Forums : Adobe Photoshop
lisa rolley
on Apr 30, 2009 at 9:10:47 pm
Hey friends,
I tried doing a search on this on the forum but no luck and i need to layoff by EOD!! here goes:
I have been asked to layoff an HDCAM tape with multiple types of Letterbox Mattes so i need to create these in Photoshop and obviously have alpha info where picture would be and black bars elsewhere for the ltrbx.
I have never had to do this and am not very strong with PS - can anyways quickly explain to me how to do this in photoshop for one of the ones i have to make and then obviously i will understand how to make the rest.
i did the math already so i know what frame sizes they need to be i just dont know how to properly make this in PS and export for use in FCP.
Here are the HD sizes i need for creating Letterbox Mattes:
Thank you for any help you guys can provide
Emily Carmichael
Re: creating Letterbox Mattes in Photoshop for FCP HD Layoff - HELP!
on May 12, 2009 at 9:51:12 pm
Yeah, that's annoying.
You know FCP has a whole host of widescreen mattes in the video filters category, right?
Effects>Video Filters>Matte>Widescreen. You can select different dimensions once you apply the filters.
But if you need an odd size or something, here are steps:
-Create a new photoshop document that's the SIZE OF YOUR FCP SEQUENCE
------photoshop has presets for most frame sizes under Preset>Film and Video
------choose background contents "transparent"
-Edit>Fill the background with black
-View>clear guides to clear the title safe guides that are there
-View>New Guide to make two horizontal guidelines for the boundaries of your letterbox
-Make sure View>Snap is checked
-Use the marquee tool (top tool, or press M) to select the area between the guidelines and go to edit>clear.
The picture area should now be gray checkerboard, indicating transparency. If the picture area is white, it just means you chose a white background when you created your document. You have to go to Layer>New>Layer from Background and try the operation again.
Then save as PNG and throw it into FCP. You could make a black and white image and use it as a matte but... why bother. This way's fine.
© 2018 All Rights Reserved
