PowerPoint Template
COW Forums : Adobe Photoshop
David Yowell
PowerPoint Template
on Apr 30, 2009 at 12:12:39 am
I would like to be able to import a PowerPoint template into Photoshop so that I can edit it and use it with a short video. However, when I try to import it, it tells me that it can't import it as it is not the right kind of document. Does anyone know how to do this or do I need to just Print my screen and make a JPEG out of it? Thanks for the help.
James Henley
Re: PowerPoint Template
on Apr 30, 2009 at 3:38:12 pm
Can't remember if its the same in earlier versions, but in Powerpoint '07 you can save one or all of the slides as image files (file > save as > other formats > select jpg or whatever from dropdown list).
Hope that helps.
James
