flight board look
COW Forums : Adobe Photoshop
Dan Roth
flight board look
on Mar 17, 2009 at 7:28:22 pm
i want to create the effect of the text on a flight deperture display, as seen in the image i uploaded. how can i use photoshop to create that dotted text look?
Abraham Chaffin
Re: flight board look
on Mar 17, 2009 at 8:04:09 pm
A good technique to create this look would be to create a work path from a text layer and then apply a stroke path using a pencil or brush. You can adjust the look by adjusting the brush settings and spacing.
1) Create the text
2) Right click on the text layer > Create Work Path
3) Set your brush or pencil settings to have a large distance of like 300% and a small point of like 1
4) Create a new layer
5) Select the path from the paths tab
6) Select the new layer
7) Stroke the path with brush by clicking the stroke path with brush button or right click on the path and choose that option.
For the Perspective part you might take a look at this podcast / video tutorial:
© 2018 All Rights Reserved
