loss of transparancy while saving EPS
COW Forums : Adobe Photoshop
Serge Nijsten
on Feb 12, 2009 at 7:52:35 pm
Hello,
Of course I've read the abobe help and manual but I still don't manage to keep transparency while saving an ai-file
into an EPS.
What I did is the following:
I created a rectangle with rounded corners. Before adding an outer blur effect (Effect > Stylize > Outer blur) I selected Effect > Document Raster Effects Settings and put the resolution to 300 ppi, background to transparant, Options: Anti-alias, Add 0 mm Around Object and Preserve spot colors when possible.
Then under Edit > Transparency Flattener Presets I choose the [High Resolution] preset.
After having a simple example to test, I saved this ai-file as an EPS and opened this EPS file in Photoshop.
What happened? I lost transparency.
Can anyone please tell me what i'm doing wrong?
cheers from Holland,
Sergey!
Jeff Kelley
Re: loss of transparancy while saving EPS
on Feb 13, 2009 at 5:29:31 pm
While I'm not sure why this happens, I do know that you can drag and drop from IL to PS and it seems to work. I'm going to try a few things and I'll get back to you
Another thing that works is export to Photoshop.psd
http://www.willinois.com
