Animated Gif Frame Rate Questions
COW Forums : Adobe Photoshop
joseph wilkins
on Jan 7, 2009 at 9:34:59 pm
I have a 2 frame animated gif that I want to slowly rotate from frame to frame at 1 framer per second.
Currently when I export it, it is blinking on and off at such a fast speed you cannot read it
Any idea how to slow it down?
Nathan Grealish
Re: Animated Gif Frame Rate Questions
on Jan 7, 2009 at 9:59:49 pm
If you are in the "Animation" window, you should see your two frames in the animation window. At the very bottom of the snapshot should be an ammount of time with a down arrow next to it. Is "1.0 seconds" clicked on each frame?
Always Start with the End in Mind
