loading new textures presets
COW Forums : Adobe Photoshop
tony wise
on Dec 30, 2008 at 7:37:09 pm
I took a cu of a tennis ball and I'm trying to load it into the pattern presets so I can use it in texture effect to texturize text. I now have a .pat in my patterns folder in my library but it will not come up as an option with the texturize effect. What am I doing wrong?
thanks.
Mike Gondek
Re: loading new textures presets
on Jan 6, 2009 at 5:10:06 am
I assume the filter you are trying to use is filter >> texture >> textrizer.
What you can do is save a grayscale .psd file of your pattern, then apply the texturizer filter, use the flyout menu in textrizer choose load texture and then choose the .psd you saved.
