PS CS3 - Pixel Aspect Ratio
COW Forums : Adobe Photoshop
Jonathan Capra
on Oct 23, 2008 at 10:39:50 pm
Is there a way to shut off Pixel Aspect Ratio Correction universally in Photoshop, rather than a case-by-case document-by-document basis?
Mike Gondek
Re: PS CS3 - Pixel Aspect Ratio
on Oct 25, 2008 at 5:18:52 am
You woudl have to write an action that reset the pixel aspect ratio to square, and then insert menu item >> open as the second step of your action. You can export this action as a droplet, if you like to drag and drop to open your files.
Richard Harrington
on Oct 25, 2008 at 11:39:03 pm
I think he means the preview function and not the actual non-square pixels
1. In CS4 its much cleaner
2. You can make an event using Script Event Manager.... say with every open document play back an action. Simply make an actionthat turns it off
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
