Scaling
COW Forums : Adobe Photoshop
Michele Wheeler
Scaling
on Oct 6, 2008 at 3:53:04 pm
A couple of days ago I lost the ability to scale text, boxes and art... by dragging to fit an area. For example the text does not have a bounding box so I can't click and manually drag out to fit an area. Instead it has a blue line underneath the text. I have re-installed CS3 Suit... hoping this would solve the problem, it did not. I am assuming it is a setting issue but I have searched and can't find a solution. Has anyone had this problem and if so please help?
Kelly Johnson
Re: Scaling
on Oct 7, 2008 at 3:00:24 am
I had this a couple of times with CS2, never w/CS3.
Trash the preferences. Unless you used an un-installer, the old preferences were still there even when you re-installed.
I always just search for any files with com.adobe and then look them over in the finder to see if they are ones to trash.
Keith Thomason
Re: Scaling
on Oct 7, 2008 at 5:31:17 am
You didn't accidently hide your bounding box did you? Go under view and see if you can "show bounding box".
