Creating Sequential Numbers
COW Forums : Adobe Photoshop
Evan Schafer
on Jun 11, 2008 at 5:25:21 pm
Is there a way to generate a LOT of sequential numbers, other than brute force, using CS2? I need to create numbers from 1-350 to place on land plots. Placing them will of course take time but, is there a way to simply generate them all automatically?
Mike Gondek
Re: Creating Sequential Numbers
on Jun 12, 2008 at 12:52:55 pm
I create them in Excel, then copy and paste them.
(EG: in eExcel)
put a 1 in the top cell
put a 2 in the cellunderneath
Then select both cells and drag the blue dot on the bottom right of you selections downwards until you reach 350.
A far as being abel to move each number individually, my best recomendation would be to then convert this to a vector shape in Photoshop, and then use the solid path selection tool (but be careful not to miss when selcting).
© 2018 All Rights Reserved
