Gradient on a stroke
COW Forums : Adobe Photoshop
Stephan Dube
on May 20, 2008 at 3:23:05 pm
Im trying to put a gradient on a stroke however I am unable to do this. the work around thatI found is to do a rectangle and put a gradient inside of it and use the Warp tool to make half of a circle however the circle is not a perfect half of cricle even if I put 50 "make with mesh" value. anyone has any other suggestions?
thanks
Stephan Dube
Re: Gradient on a stroke
on May 20, 2008 at 6:11:56 pm
Just in case Im not clear on my goal here is to create an arc with a gradient inside of it. However when I use the "Make with Warp" tool my half circle isn't perfect and I need it to be absolutly perfect. Inside of my half circle id like to have a gradient inside of it. thanks
