using auto-align to tile images
COW Forums : Adobe Photoshop
Emily Carmichael
on May 9, 2008 at 11:08:16 pm
I'm really excited about the auto-align layers command in Photoshop CS3, which you can use to digitally stitch layers that share overlapping content.
My question is, is there any way I can trick this command to helping me tile IDENTICAL layers? I often want to create large textures from small repeating samples (wallpaper is a great example.) Of course, when I put the same identical sample on two different layers the best place way to align them is right on top of each other, which photoshop does. Is there any way to convince it to do otherwise?
Richard Harrington
Re: using auto-align to tile images
on May 10, 2008 at 1:54:24 pm
Simplay save the image as a pattern (Edit Define Pattern) then add a Pattern Fill Layer
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Emily Carmichael
on May 10, 2008 at 8:58:46 pm
Well, that doesn't work--usually samples represent an arbitrary area, an not a single "unit" of the repeated pattern--even if you can suss out the pattern, the lighting on the edges rarely matches. You need the freedom of different layers to blend them seamlessly. This is especially true if the texture represents anything organic--sand, leaves, whatever.
The more I experiment, I think there's no way I can bend auto-align to my diabolical purposes, and I am left to use hand alignment as before.
Emily
