pixel aspect conversion question
COW Forums : Adobe Photoshop
Carl Endres
on Apr 25, 2008 at 1:04:11 pm
I used a widescreen frame capture from Premiere and then brought that into Photoshop CS3 to use as a background for a composite. I did the compositing work on it, and PS shows the widescreen aspect ratio preview and it looks great.
However, I want to print this and use it for use in a DVD cover. I have already upsized it using the 110% resampling trick.
Before printing, what should I do to prevent the squishing, that is occuring because it is using square pixels in PS.
Thanks in advance for any suggestions - Carl
Richard Harrington
Re: pixel aspect conversion question
on Apr 25, 2008 at 1:30:56 pm
Copy the layer into a document set to square pixels and the right dimensions for your DVD label
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Carl Endres
on Apr 25, 2008 at 6:25:18 pm
Thank You Richard, that worked great.
Richard Harrington
on Apr 26, 2008 at 2:02:34 am
You're welcome
