Smooth Skin Tones
COW Forums : Adobe Photoshop
Stuart Devlin-Gray
Smooth Skin Tones
on Mar 11, 2008 at 11:40:34 am
Can anyone please tell me how to create smooth, silk like skin tones in photoshop ?
Mike Gondek
Re: Smooth Skin Tones
on Mar 11, 2008 at 6:11:42 pm
Float a copy of your layer
Gaussian Blur the layer copy it a strong amount
Set the layer blending mode to soft light
Create a layer mask and paint out areas you do not want smooth
the soft light will give you that glowing sheen and rich color, you can adjust the layers opacity if 100% is to strong.
Stuart Devlin-Gray
on Mar 12, 2008 at 10:43:50 am
Thank you for that Mike, it works very well and easy to do.
Stuart Devlin-Gray
on Mar 15, 2008 at 3:15:33 pm
I know this should be simple stuff! however how do I do the layer mask part to paint out the parts I don't want effected? I have created a layer mask but can't paint on it!
Mike Gondek
on Mar 15, 2008 at 7:19:00 pm
In the layers palette click on the icon with the dotted circle at the bottom of the layer palette. This adds a layer mask to your selected layer. Then paint with black to remove unwanted times or white to bring it back. Use a soft brush and alternate brush hardness as needed.
Stuart Devlin-Gray
on Mar 15, 2008 at 11:13:19 pm
Thank you once again Mike for taking the time to reply it is very much appreciated.
Stuart
Trey Eckles
on Mar 19, 2008 at 12:36:20 am
I was looking for this info. Is this how they do it on all the magazine covers? I am looking for a tutorial that has that same effect.
Stuart Devlin-Gray
on Mar 20, 2008 at 8:39:59 pm
I'm not sure if this is how they do it on magazine covers but it does work well.
