Scripting text causes mac and pc to run out of memory
COW Forums : Adobe Photoshop
Rob Stemm
on Feb 27, 2008 at 3:39:28 am
Hello all,
I've written a script that reads text in an array and assigns that text to the selected textItem (Selected Text Layer in Photoshop). This works great for saving many files in a short amount of time, but there seems to be a memory problem if my selected text layer has different character styles. For example: if my text layer has Faux Bold or Small Caps turned on (In the Character window) when running the script. Photoshop will quickly eat up all of my computers memory making it non-responssive. This occurs on both PC and MAC. Is there any workaround to this? I'd like to be able to use these character styles on my fonts when running this simple script. Any help would be much appreciated.
Below is the script I'm running.
Rob
var defaultRulerUnits = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS;
//POINTING TO THE PATH WHERE THE FILES SHOULD BE SAVED
var cPath = Folder.selectDialog("Select a folder for the output files");
//ARRAY OF TEXT TO POPULATE TEXTITEM
var textArray = [
"Sample Text test 1",
"here is some more text you would like",
""This is an example of a quote"",
"Hope everything is going well",
"I'd like some dinner now",
"Time is of the essance",
"Do we need to go on?",
""Me" This is me in quotes",
"Colorado is a great state",
"Do you like to rock climb?"
//ARRAY OF FILE NAMES
var fNameArray = [
"01",
"02",
"03",
"04",
"05",
"06",
"07",
"08",
"09",
"10"
var AD = app.activeDocument
//LOOP THAT DOES ALL OF THE WORK
for(a=1;a<=textArray.length;a++)
var TextLayer = AD.activeLayer;
var txtRef = TextLayer.textItem;
txtRef.contents = textArray[a-1];
var newName = "";
var newName = fNameArray[a-1];
saveForWebPNG(cPath,AD,100,newName);
alert("I'm Done :)");
//SAVE PNG FUNCTION
function saveForWebPNG(toWhere,file,qual,name)
toWhere = new File(toWhere+"/"+name+".png");
var opts = new ExportOptionsSaveForWeb();
opts.interlaced = false;
opts.PNG8 = false;
opts.transparency = true;
opts.format = SaveDocumentType.PNG;
opts.includeProfile = false;
file.exportDocument(toWhere, ExportType.SAVEFORWEB, opts);
app.preferences.rulerUnits = defaultRulerUnits;
ekim wahs
Re: Scripting text causes mac and pc to run out of memory
on Feb 27, 2008 at 5:58:24 pm
Once I set the contained quotes to single quote instead of double quotes in order for the script to run, I have not had a problem running your script with Faux Bold and Small Caps on the original type layer. Are you updated to 10.0.1? Do you get out of memory error if you save without going through save for web?
Mike Shaw
Photoshop QE
Rob Stemm
on Feb 27, 2008 at 8:47:00 pm
Mike,
I'm running Photoshop CS2 Version 9.0.2. I've tried saving without going through Save for Web and this doesn't seem to help. I've also tried changing the quotes and removing many of the declared variables outside of the for loop. Below is some optimized code for the above as well as moving the loop into a main function. I've removed all instances of "'s in the array. Is this just a problem with CS2? I've even tried using a different font and setting the faux bold / small caps on the actual text layer instead of through script.
Any other ideas. Thanks for your suggestions.
Rob
var textArray = [
"This is an example of a quote",
"Id like some dinner now",
"Me This is me in quotes",
var fNameArray = [
"01",
"02",
"03",
"04",
"05",
"06",
"07",
"08",
"09",
"10"
var AD = app.activeDocument;
txtRef.fauxBold = true;
txtRef.capitalization = TextCase.SMALLCAPS;
var newName = "";
function myMainApp()
for(var a=1;a<=textArray.length;a++)
try
saveMyFile(cPath,AD,newName);
catch(e)
alert("Error Caught: " + e);
function saveMyFile(toWhere,file,name)
saveOptions = new PNGSaveOptions();
file.saveAs(toWhere, saveOptions, true, Extension.LOWERCASE);
myMainApp();
Rob Stemm
ekim wahs
on Feb 27, 2008 at 10:47:33 pm
OK I see the slow down when using Faux Bold in CS2. If I just use small caps is seems to be going OK. Unfortunately I have not found a work around for you in CS2. CS3 looks to be handling this much better than CS2.
Mike Shaw
Photoshop QE
Rob Stemm
on Feb 28, 2008 at 4:13:32 am
Thanks for your help. Looks like I finally have to go for the upgrade.
Rob
Rob Stemm
