Broken Pieces
COW Forums : Adobe Photoshop
Joe McArthur
Broken Pieces
on Feb 9, 2008 at 6:33:12 pm
i need to make an image look like it has been broken into scattered pieces (3d look) . . . is there a tutorial out there for this . . . any suggestions?
Thanks in advance
Mike Gondek
Re: Broken Pieces
on Feb 11, 2008 at 2:34:30 am
After Effects has a great shatter effect for doing this.
Photoshop is not a 3D program, but Alien Skin makes a set of filters called Xenofx which has shatter and cracks.
Del Holford
Re: Broken Pieces
on Feb 11, 2008 at 8:43:10 pm
...and if you can't afford the plug-ins buy a pane or 2 of glass at the hardware store or Lowes/HomeDepot, place it on a white sheet or black cloth and gently break it (them). Photograph that with your digital camera and use that photo as a layer over the image you want. Adjust lighting and transparency until you get the look you want. Be sure to clean up your mess and get all the glass off the cloth. :-)
Del
fire*, smoke*, photoshopCS3
Charlotte Public Television
del underscore edits at wtvi dot org
