Photoshop scripting help
COW Forums : Adobe Photoshop
graphic43
on Jan 17, 2008 at 6:40:53 pm
I have a PARAGRAPHTEXT text box in Photoshop that I plan on populating with text using .jsx scripting. One thing I need to do is to center the text box vertically between two y values and save a final image. Is there anyway for the script to determine if the text has wrapped to the second line in the PARAGRAPHTEXT text box? If I know there are two lines of text the y value will be different than if there is only one line of text.
Thanks for any advice,
Rob
ekim wahs
Re: Photoshop scripting help
on Jan 17, 2008 at 9:44:01 pm
try using
var x = app.activeDocument.activeLayer.bounds
//returns array of left side , top, right side, bottom
alert("bottom = "+x[3])
Mike Shaw
Photoshop QE
graphic43
on Jan 18, 2008 at 2:01:56 am
That did the work. Thanks for your help!
Rob
