Converting from RGB to CMYK
COW Forums : Adobe Photoshop
Adam Peters
on Oct 23, 2007 at 12:35:02 pm
I'm trying to convert an image from RGB to CMYK in Photoshop 7. When I convert the image it changes the colour and the quality quite a lot. Is there anyway to convert the image without any change?
Adam
Mike Gondek
Re: Converting from RGB to CMYK
on Oct 23, 2007 at 3:10:49 pm
There will always be some change in converting RGB to CMYK. Some RGB colors like red or yellow convert well to cmyk and others like 255 blue do not. Your monitor is also an rgb device, so the representation is not as accurate for CMYK.
Overall you will notice less saturated colors in CMYK, because RGB light is cleaner and than CMYK inks.
Your color settings also play a part in the conversion, but that is a very long topic and make sure you are set to US Prepress Default.
