help with vanishing point export
COW Forums : Adobe Photoshop
marcoshoracio
on Oct 23, 2007 at 11:07:50 am
Hi there,
I'm trying to export the VP data I created on a PSD file but I don't have that option on menu inside the Vanishing point filter workspace...
I went back to the Photoshop main interface and can't find that option under EXPORT either.
And that's not my only problem. I'm trying to use the "option click" + drag shortcut to change the angle of a plane from its 90 degree default and that's not working neither.
Am I missing something?
Btw, I'm using a full Professional CS3 package, with a Mac 10.4.8, Dual Quad...
Marcos H.
Quad G5
2GB RAM
OS 10.4.7
FCP 5.0.4
AE 6.5
Richard Harrington
Re: help with vanishing point export
on Oct 24, 2007 at 1:55:53 am
It is in the submenu of the Vanishing Point window (when filer is running)
If you have the book Photoshop for Video... you can download a full tutorial from the book's website
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
Jason Hare
on Mar 31, 2009 at 12:40:24 am
I am having the same problem as the original poster. I was trying to do a tutorial from this website when I discovered that when I click the submenu within the Vanishing Point window I do not have any export options.
I am running Photoshop CS3 on a Macbook Pro 2.33g Intel Core 2 Duo with 3gig Ram.
I tried reinstalling both After Effects and Photoshop but it has made no difference. The only options I have in the menu are:
Show Edges
Show Measurements
Render Grids to Photoshop
Allow Multi surface operations
Clip operations to surface edges
The last two options are greyed out.
Hope someone can help!!
Andrew Dickinson
on Apr 3, 2009 at 3:04:30 pm
I am having this same problem myself. I'd like to use the features for After Effects. But, it turns out you need Photoshop Extended to be able to export to After Effects.
Jason Hare
on Apr 12, 2009 at 1:37:07 pm
Ah so that is the answer. What is the point of giving out half a filter I wonder?
Thanks for the tip.
Jason
