Replacing image.
COW Forums : Adobe Photoshop
Scott Davis
Replacing image.
on Aug 22, 2007 at 5:17:48 pm
I've created a menu for DVDSP in Photoshop. I want to create a secondary menu that is exactly the same except for the images used for the buttons. Is there an easy way to replace the current button image with a different image and maintain all the attributes of the original layer (ie cropping, scaling, feather, etc)
Scott Davis
Scott Davis
Richard Harrington
Re: Replacing image.
on Aug 28, 2007 at 1:11:02 am
Use Smart Objects for the layer.... then apply layer styles...
You can replace the contents of a Smart Object.
You may also want to attach a mask but unlink it
Scott Davis
on Aug 28, 2007 at 1:25:50 pm
Richard thanks, (for the reply and I've been going through your podcast). I tried Smart Objects. I got it to kind of work. I could not get it to "take" the scaling, attributes or the cropping attributes. I will try some more today though.
Scott Davis
Scott Davis
Richard Harrington
on Aug 30, 2007 at 11:21:52 am
Add a Layer Mask to the Layer (outside the Smart Object)
Unlink it (click the chain icon)
That will get you closer =)
You also may want to explore using Data Sets as a way to do this
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
