crappy computer and CS3 fading pallets cause crash
COW Forums : Adobe Photoshop
cowcowcowcowcow
protohobo
on Aug 22, 2007 at 12:30:27 am
Does anyone know if you can turn off the fade in/fade out effect on the pallets in CS3?
I am pretty sure it is what is causing crashes on an older machine here. It's a Dual 1.2 processor g4 and if it is in photoshop and the animation pallet is open and you hit save then switch applications there is a good chance a crash will happen.
Crashes also happen the same way with out the animation pallet open but not as frequently.
Does anyone know if it is possible to kill that fade out effect of the pallets?
thanks
