virtual memory in C2
COW Forums : Adobe Photoshop
rick kz
on Aug 14, 2007 at 9:24:21 pm
the cpu is a HP8400 w/4Gb ram and winXP (32bit so only 3Gb ram)- 5 internal SATA drives are installed for 1.3TB of storage- the files are not that large but can get up 1GB-
currently C2 will freeze or hang minutes after a hour or so of work with multiple files-
what would be the best recommended virtual memory settings for C2 to keep stable application performance
how about the boot.ini file? suggested mod?
thanks very much in advance
rick kz
Re: boot.ini switch and virtual memory in C2
on Aug 14, 2007 at 11:47:00 pm
with so many options available, can anyone recommend the best boot.ini 3Gb switch options to utilize the 4Gb of installed ram in this 32bit winXP cpu?
again, many thanks in advance
