outline shape
COW Forums : Adobe Photoshop
davidquad
outline shape
on Aug 1, 2007 at 12:26:50 pm
i have drawn a vine, which i would like to make a copy of and use as an inner outline which i can fill with different colours. i have tried making a copy and then using the scale tool. is it because it is a complex, curvy shape it will not 'fit' inside. any help would be appreciated.
pixelmeister
Re: outline shape
on Aug 3, 2007 at 4:24:38 pm
Hi there,
I'm not sure if I understand exactly what you are trying to do, could you post a picture?
Adi
Mike Gondek
Re: outline shape
on Aug 12, 2007 at 1:19:00 pm
To get inner outlines only, use your original shape as a mask on top of a stoked and filled version of your path. Using the appearance palette is very very very handy if you need multiple strokes and fills.
Offset path is usefule, btu the contolr you get form adjusting the stroke values in your appearance palette is much quicker and accurate when doing revisions whiel designing.
