Why some tiffs won'd save as jpeg's ?
COW Forums : Adobe Photoshop
talbotgrad
on Jun 8, 2007 at 6:47:27 pm
I scanned a bunch of slides using Nikon slide scanner and some of the Tiff files will not allow me to "save as" to a jpeg format (only three options given).
However, most of the tiff files allow me to "save as" jpegs without a hitch. ( THe format option is much longer with jpeg as one of them)
I can't figure out WHY?
It is a mystery to me.
Anyone have an idea?
The scans were done at the same time. They are all rgb mode and the same size. I know I'm missing something!
Larry
Joe Rugby
Re: Why some tiffs won'd save as jpeg's ?
on Jun 9, 2007 at 1:30:11 pm
It could possibly be a similar issue to this:
From time to time I'll get an image where I copy & then can't paste into a new document. Its often a bits per channel issue.
Photoshop menu> Image> Mode> 8 bits per channel will give you the most saving options.
Cheers,
Joe
L.O.A.
TiffaniB
on Jun 11, 2007 at 2:17:49 pm
The best way to eliminate all of the caveats with saving as a jpg is to use the "save for web" function... this will open up a window, where you can choose the jpg settings and then save it out.
Tiffani B
