Photoshop Extended Animation window
COW Forums : Adobe Photoshop
JD Cochran
on Jun 4, 2007 at 8:47:41 pm
I'm currently using the healing brush in animation window to roto / remove a dot from a number of video clips. I was wondering if there are keystrokes to advance the CTI in the Animation Window Timeline?
It would sure make the process easier than repeatedly having to click the Healing brush on the dot and then move the cursor down to the Frame Advance button and then reposition the cursor/Healing brush on the dot once again in the new frame. This can get monotonous after awhile.
ekim wahs
Re: Photoshop Extended Animation window
on Jun 7, 2007 at 9:30:41 pm
You can assign keyboard shortcuts for Go To > Next Frame and Previous Frame in Edit/Keyboard Shortcuts. Select the Palette Menus item in the popup and expand the Animation (Timeline) item to get at the commands to set a Keyboard shortcut for.
Mike Shaw
Photoshop QE
© 2018 All Rights Reserved
