cant select more than 1 layer in layer pallet
COW Forums : Adobe Photoshop
Mister T.
on Apr 27, 2007 at 12:14:29 pm
Hey,
I cant seem to select several layers add ones(doesnt go with shift/option select). How come? Something in the preferences? I cant find it. I dindt use to be like this(i gess, i dont use photoshop that much).
Im using a mac. CS1 PSD.
T.
Peace
Mike Gondek
Re: cant select more than 1 layer in layer pallet
on Apr 27, 2007 at 1:58:41 pm
I believe CS2 is when they added being able to select multiple layers. You would have to link layers in CS1 to do a transform on multiple layers, or put them in a layer set.
Anyone else, please correct me if I am wrong, as I dont have CS1 and am going from memory.
wuzelwazel
on Apr 27, 2007 at 7:41:51 pm
You're right, you can't select multiple layers in CS1. The workaround is grouping them, but this can be a pain when you're trying to select a layers that aren't directly above or below one another in the layers palette. One of the many annoying things about using CS1 at home after enjoying CS2 at work =(
