how can I get this effect?...
COW Forums : Adobe Photoshop
mrshow555
on Apr 19, 2007 at 1:05:06 am
I'm looking to take a photograph and using filters and whatnot achieve a simple yet detailed drawn look to it. I'll be cutting out the object that I want to affect, but what filters and methods would best give me that old fashioned look that's so popular these days with indie bands and t-shirt designers.
Examples:
http://drmcninja.com/images/raptorlarge.gif
http://www.urbanoutfitters.com/images/us/local/products/productsall/p326248...
http://mapsandatlases.org/images/row1_2b.jpg
Jacki in Atlanta
Re: how can I get this effect?...
on Apr 19, 2007 at 2:06:03 am
Those are original artwork, not from photos.
But experiment with art filters. It does not take long to click on a filter and look at the results or check out the filter gallery.
-Filter
-Filter gallery
You might like this:
-Image
-Adjustments
-Threshold
Joseph W. Bourke
on Apr 20, 2007 at 7:26:10 pm
At least two of those images are woodcuts or linoleum cuts, made by cutting the inverse image into a block of wood or linoleum, then using the block as a printing plate.
One way you might go is to make your image black and white, then use the brightness and contrast filters to simplify your grey levels, then make a selection from the black or white that's left and paint using that selection. You might want to do a couple of passes using variations on the brightness and contrast. This could also work separating the color channels and working that way. Experiment!!
If I remember correctly, there was an Adobe Gallery Effects filter called woodcut that may still be in Photoshop.
Joe Bourke
Art Director / WMUR-TV
